kkenaga
#1 Posted : Monday, November 19, 2007 12:00:54 PM(UTC)
kkenaga
I have a Jenn air gas range and the oven and Broiler will not light. I have replaced the Ignighter, Gas regulator and Oven Valve, but still will not light. the ignighter glows but no gas to the oven or broiler.
Any help would be appreciated.
#2 Posted : Tuesday, November 20, 2007 11:45:14 AM(UTC)
The gas pressure regulator has the gas shut off valve for the oven gas line.
It is located on the left side of the regulator. You can see it on the gas controls break down diagram (#21).
Make sure it is open and gas is coming to the gas oven valve.
