My mw has shut down. I want to test the fuse, but can't find how to access the part.
Hello jawhite. Remove the outer cover off the microwave. You will see the fan motor on the right looking at the microwave from the front. The fuse is located above the fan motor. The fuse is number 101 in the parts diagram. Hope this helps. Part number: AP2631556
