garycarson
#1 Posted : Wednesday, July 27, 2011 12:10:00 PM(UTC)
garycarson
My Kitchen aid dishwasher model KUDM01TJ8269906C has no lights on control panel and the keys do not function. Unit worked OK the last time it was used and completed the entire cycle. I have replaced thermal fuse assembly, but later found that the original was OK. Checked door lock mechanism and power in and out is functioning. I think I'm down to either the control board or control panel. Not sure how to check these or how to test.
GC
oakdaledishwasher
#2 Posted : Tuesday, August 16, 2011 9:24:47 AM(UTC)
oakdaledishwasher
hello. did you find out what the problem was? I seem to be having the same problem....my unit stopped working...no lights nothing on control panel.
garycarson
#3 Posted : Wednesday, August 17, 2011 10:37:18 AM(UTC)
garycarson
Ended up calling a repairman because no-one answered my post. It was the control board. Guy said by his experience, that's usually the problem, not the button assembly.
