i have no spark at any burner, but i do have gas and power. Question : is there a "mini" circuit breaker on the unit itself? If not does this sound like the spark module is gone? I haven't taken it apart yet, as I wasn't sure if parts are still around, and if it was worth it. :confused: But i do see some parts are still available. So waiting for advice from you guys.
I have read most of your other forum, good information so far.
thermador model SGT36G serial # 89050523
thanks thorne electric
If there is a power to the unit then most likely the problem with your stove is a bad spark module. In order to replace it you have to remove the top panel. - The part number for the spark module AP2821617 - The part number for the special tool to remove burner rings AP3393645 - Here are the break down diagrams for the Thermador stove Model SGT36G01Gene.
