jmatlin
#1 Posted : Sunday, November 18, 2007 7:12:33 PM(UTC)
jmatlin
I Have A Kenmore Elite 110.24982300 That Quit Washing And Spinning, I Think The Coupling Went Out But I Can Not Get Top Off Of It, Do Not See Screws To Tilt Control Panel Back. It Has Some Side Panels And It Looks Like A Hing In The Back But What To Do? Should I Go Through The Front Panel Or From The Bottom To Check This. Its In A Tight Spot And Will Be Hard To Lay It On Its Back
ApplianceJunk
#2 Posted : Monday, November 19, 2007 4:27:09 AM(UTC)
ApplianceJunk
Check out this repair guide and see if it helps.
hurst
#3 Posted : Sunday, January 6, 2008 1:49:43 PM(UTC)
hurst
hi, i am having the same problem if you do find this info will you please email it to me at jhursts@suddenlink.net......thanks jim
