onlyalad
#1 Posted : Friday, March 20, 2009 1:09:22 PM(UTC)
onlyalad
hello...
I purchased and installed an element and a thermostat for this devil dryer. It still does not produce any heat... any suggestions, please?
Note: It appears that the machine works ok outside of this issue.
Thank you,
David
Drags1998
#2 Posted : Friday, March 20, 2009 3:32:36 PM(UTC)
Drags1998
Did you check BOTH circut breakers in the home? (shut them off, then back on):)
onlyalad
#3 Posted : Friday, March 20, 2009 5:50:23 PM(UTC)
onlyalad
yes.. I tried that.. thanks. anything else?
#4 Posted : Saturday, March 21, 2009 2:37:34 AM(UTC)
I believe that a PLEA50 is the same as a LEA50 so the following should apply.
Here is the parts breakdown
Replacement parts for AMANA LEA50AW | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/m...ary/docs/RS3200005R2.pdf
Wiring diagram is Page 11-5 and 11-6
I can see only one thermal fuse so it will be the one on the heater assembly, Item 6 in "Rear bulkhead" section.
If you do not have a meter, you could:
Unplug the unit.
Short the two wires going to the fuse together.
Tape them up so they cannot short to the frame.
Plug it back in and give it a try.
If it is the fuse replace it ASAP as this is a safety device and the machine should not be run without it.
Also clean and check the vent system and the blower wheel both are common causes for the fuse to blow.
The below may be too late but there is a saying "It is never too late"
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
