BobDu
#1 Posted : Friday, March 20, 2009 8:23:54 AM(UTC)
BobDu
I had the cam riser replaced by a tech. The door now swings open very easily, but does not stop. I recall - I think - that the door would open about 90 degrees. It now feels like the door is going to break off. Was the cam put in wrong? Is there a stop that is broken? Thanks for your help
woodchuckie
#2 Posted : Friday, March 20, 2009 8:34:52 AM(UTC)
woodchuckie
There is a door stop at the hinge. Part 12 on this diagram of your fresh food door. Replacement parts for GE TFX27PRXAWW | AppliancePartsPros.com
It could have been reinstalled backwards or left off. There is one on each door. I had to swap mine to make it stop correctly as one is for the right side and the other for the left.
bdubs108
#3 Posted : Monday, May 10, 2010 5:47:24 AM(UTC)
bdubs108
How do you remove the screw for the door stop. What head is on the screw? it looks like an allen but different???
