Javier
#1 Posted : Thursday, July 26, 2007 3:10:13 PM(UTC)
Javier
My dryer dries to slow. I needs about 3 to 4 cycles for it to dry. I went to an appliance parts store and they told it was the coil gas valve. I replaced them, but it does the same thing. The flame turns on for about 10 sec. and then it turns off. It turns back on within a minute, and it keeps doing the same thing till it finishes. What else can it be?
Adam / APP Team
#2 Posted : Thursday, July 26, 2007 3:51:45 PM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
Dear Javier,
In most cases when you initually turn the dryer on and the flame only stays on for less than 30 seconds has to do with the coils.
There are other things it may be
Click here for someone with a similar problem
Everything else is generally the same exept you have a flame sensor, igniter and coils while they have an element.
CLICK HERE FOR PARTS BREAKDOWN ON YOUR SPECIFIC MODEL
Javier
#3 Posted : Tuesday, August 21, 2007 5:35:46 PM(UTC)
Javier
Thanks, Adam.
I already changed the coils and it still does the same thing. I'am wondering if its the heat sensor?
