Seems to work with the exception that water continues to flow into the unit even when off. Door open...Water stills comes in. We came home to find our kitchen floor flooded. Help:confused:
Most likely the water inlet valve is stuck open. The part has to be replaced. - The part number for the water inlet valve AP3790911 Gene.
