barbarastjohn
#1 Posted : Sunday, July 24, 2011 7:14:14 AM(UTC)
barbarastjohn
The motor seems to be running but I do not get water in the dishwasher:(
#2 Posted : Sunday, July 24, 2011 5:58:20 PM(UTC)
Replacement parts for FRIGIDAIRE 61-1120-10-00 Tap(v1) / 24 " Built - in Dishwasher | AppliancePartsPros.com
Check the float (Item 26 in Section 4) on the overfill assembly. Sometimes it can get stuck in the up position. If it is then usually cleaning it will fix the problem.
If the overfill switch is being activated, check for 120 volts across the fill valve (item 3 in Section 6) when it should be on.
If there is no voltage, check across the fill valve/overfill switch (they are wired in series).
If there is no voltage there, then the control is probably toast.
If there is voltage, then check across the overfill switch. If there is voltage across the switch then the switch is shot.
If there is 120 volts across the fill valve then either the fill valve needs replacing or it's filter needs cleaning.
There is a screen filter built into the input side of the valve. Remove the valve from the unit and check/clean the screen filter.
Do not permanently remove the screen filter from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
Motor Runs but No Water (Dishwasher Repair)
by ndquale 6/18/2008 7:13:52 PM(UTC)
