Doug 23
#1 Posted : Thursday, March 19, 2009 2:34:16 PM(UTC)
Doug 23
between the insulation and the freezer door ice builds up, then when the freezer defrosts water leaks onto the floor when you open it.
woodchuckie
#2 Posted : Thursday, March 19, 2009 3:54:43 PM(UTC)
woodchuckie
I'm not sure this is what you're describing but Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
maytag refrigerator/ freezer (Refrigerator & Freezer Repair)
by Guest 5/21/2021 5:09:50 AM(UTC)
Refrigerator/ Freezer not working (Refrigerator & Freezer Repair)
by J. Cook 1/21/2012 1:34:47 PM(UTC)
side by side refrigerator/ freezer (Refrigerator & Freezer Repair)
by azstyle4u 11/9/2011 7:36:33 AM(UTC)
Amana Refrigerator/ Freezer Problem (Refrigerator & Freezer Repair)
by 7cs777 9/1/2010 10:38:01 AM(UTC)
