paulclark
#1 Posted: : Friday, July 22, 2011 6:06:20 AM(UTC)
paulclark
model kuds01Ijbs
sirs,
my kitchen aid dishwasher stop working last week and had an electronic burnout smell. replaced the concerned burnout area(fuse) still burned out at new fuse. called and ordered your electronic control assemble part # please confirm correct one AP3775964 with another new fuse. Withdrew previous assemble with your new replacement with fuse. Started up, worked for one cycle, then did not drain. Now does not come on despite making contact with all buttons, however does have power as lights up "2" then "1" as in minutes. Thinking it may be the door catch huh?is this a critical area to to function?
I opened up area upon drainage, minor debris, tried again, now action. also get three lines --- upon panel. please advise, my wife is calling me elcheapo, but rpr. man wants 85.00 to show, plus labor rate and iflated parts. Would appreciate a rapid response on this matter.
paul clark
paulclark
#2 Posted : Friday, July 22, 2011 6:10:38 AM(UTC)
paulclark
by the way, the new ordered replacement part that i received from you was somewhat different. upon one of the interior plugs, one now goes perpendicular to the other 5 prong plug. The initial with the unit had both horizontal, now one is vertical and the other is horizontal, Other entries do lightup, but do not funchtion, always displays "clean" but no function. please sdvise
part number AP3775964
model washer kuds01Ijbs
paul clark
