Our Whirlpool oven randomly give error code F2 - E6 “Cancel key drive line open”, some time after while the error clears and oven can be used again. Should I replace the Control panel assy. W/membrane switch (white model), Part Number: AP3131745 or replace Control board - Part Number: AP3767567 Thanks, SJ
In such situation I would replace the control panel. - Here are the break down diagrams for the Whirlpool oven Model RBD305PDQ8Gene.
