When I pre heat my whirlpool gold double oven accubake, it seems to start fine, then the clock slowly fades away, the oven gives several fast beeps, then shuts off. After an hour or so, the clock is back on. Is there a quick fix/reset for this or does this sound like I need to replace my entire oven control? Thanks in advance.
Follow up - now the clock/panel doesn't work at all. I think I have my answer, time to replace the control board.
