Of course the warranty just expired and I'm not sure where to even start. The washer seems to work fine, but stops when it reaches the rinse cycle. I tried adjusting the cycle knob to another rinse or even to just start over on a cycle to get water into the tub and aggitate, but it will not run water again... at least not until it's sat for about an hour or two.
Help! Any thoughts? I'm sure that I could probably fix it, but I'm frustrated and don't know where to start. :confused:
Thanks for your help!!!
Check the screen in the water inlet valve to make sure it is clean.
