W9RUK
#1 Posted : Tuesday, July 19, 2011 11:41:16 AM(UTC)
W9RUK
Unit was working fine for two days after moving into new home. Then stopped dispensing water and ice. Motor does not appear to run in any position. When using the Water, Crushed ice, or Cubed ice function nothing happens except the light flickers next to the dispensor. The ice maker is still making ice however but I can not get it to dispense the ice or water. Issue started after freezer door was left partially open overnight.
Minnesnowta
#2 Posted : Wednesday, July 20, 2011 11:07:35 AM(UTC)
Minnesnowta
Have the same problem under the same situation after freezer door left open all night. All water lines are fine. Try unplugging and then replugging the wire harness at the bottom of the freezer door. I did this and now I can get ice but water is still extremely slow. Replaced water inlet valve with no luck. Wondering now if it's electrical somewhere else or if this harness is bad. GE profile fridge only 5 years old
