2 Pages<12
fgumin
#11 Posted : Thursday, July 21, 2011 8:25:31 AM(UTC)
fgumin
No, both work. Its a GE freezer on top. Probably from about 98/99.
yesterday I unplugged it and plugged it back in and it started to work brieflly, maybe for a half hr.
#12 Posted : Thursday, July 21, 2011 2:11:31 PM(UTC)
So if you stick a portable fan on the back of the fridg to cool the condenser, everything will work just fine,is that true?
engraver
#13 Posted : Sunday, July 24, 2011 12:57:21 AM(UTC)
engraver
Richappy, I have a similar problem and a portable fan has made the freezer/fridge work normal as the condenser fan was stopped. I did get the fan started again by spinning it by hand. Is this a sign the motor is going? or needs cleaning?
I have an Amana tx121a3 that is doing this. I have ordered a replacement motor hoping that will solve the problem.
#14 Posted : Sunday, July 24, 2011 2:26:40 AM(UTC)
Check your model #
engraver
#15 Posted : Sunday, July 24, 2011 8:48:08 AM(UTC)
engraver
Oh model # TXI21A3.
The condensor fan is running like it should now but will still replace the motor on it as I can see no reason for it to do what it did other than it's time is nearing the end.
2 Pages<12
