I Have A Question About May Frig.maytag Model #msd2957aew.the Frig Part Will Not Cool Down And The Freezer Part Is Sub Part Performance.also Water Accumulates On Bottom Of Freezer Like A Glasier All The Time.what Should I Check First.i Am A Good Technician And Just Need Some Guideance In The Right Direction.any Known Common Concerns With This Brand And Model? @ Evaporator/heater System?.any Help Would Be Apprieciated.thanks-t/o.:)
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too. check defrost timer, defrost heater, Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.comIf they are good the problem will be the adaptive defrost control. Part 13 on the diagram of your controls. Replacement parts for MAYTAG MSD2957AEW | AppliancePartsPros.com Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Thanks For All The Help And Info-.i Put Th Adc Module In And Totally Defrosted The Glasier Around The Evaporator Assembly,cleaned Out The Frosen Drian Tube-tested Thr Defrost Heater And Thermostat-good.fired It Up And It Hasnt Worked That Good Sense I Bought It,also Note!!! The Auto Ice Maker Started Working Again,possibly Related To A Sub-par Temp In The Freezer Compartment.!!! Thanks Again.!!!
