smacha
#1 Posted : Tuesday, March 17, 2009 7:18:46 AM(UTC)
smacha
Over past days I noticed that this unit has developed short run time with ON time of about 1 minute with ON/OFF cycling of about every 3-4 minutes.. The unit does cool, but it does not get as cold as it should be. I cleaned the coils and replaced the compressor relay and overload protector, but this did not improve the performance. Compressor seems to get only barely warn to the touch. Where should I focus next? (thermostat?, defrost timer? low refrigerent?) Thanks for your replies.
woodchuckie
#2 Posted : Tuesday, March 17, 2009 7:50:22 AM(UTC)
woodchuckie
Replacement parts for WHIRLPOOL ED25DQXBN00 | AppliancePartsPros.comTry turning the thermostat as cold as it will go. If it still cuts off often you can try bypassing the thermostat. If it runs then, the thermostat is the problem. Part 9 on the diagram of your controls.
smacha
#3 Posted : Wednesday, March 18, 2009 5:46:49 AM(UTC)
smacha
Thankyou, for your reply,
So I short-circuit jumpered the thermostat, and I now get continual operation. The thermal exchange coils are heating up. Now its time to order a new thermostat. I notice the pictorial of the thermostat in the on-line catalog that integral to this part is a lengthy capilliary tube. What procedures are involved with the replacement of the thermostat? Will this be a chore?
woodchuckie
#4 Posted : Wednesday, March 18, 2009 6:10:41 PM(UTC)
woodchuckie
Just thread the new tube to the same place as the existing one. It's not a hard job.
smacha
#5 Posted : Friday, March 20, 2009 1:54:44 AM(UTC)
smacha
Your right. After studying the route of the thermostat tube, replacing the thermostat is straightforward. Since the replacement, the refrigerator seems to be working well. So in restrospect, I replaced compressor relay, overload protector, and thermostat which is about $70 altogether in parts cost, compared to about $1500 - $2000 for a new refrigerator. I don't understand how the latest new refrigerators have escalated so much in retail price. In these days we all are becoming more skeptic in why the cost of goods go up. I doubt that real quality and reliability have improved. I wish someone could explain and justify it for these refrigerators.
Maytag Stops After Short Run Time (Dryer Repair)
by dbattista 2/10/2013 7:39:29 PM(UTC)
