I do not get a spark to any of the four burners. Everthing else works. Can you give me any reason for this problem? If it is the ignitors, do I have to replace all four? Thank you for your assistance. John
Here are your parts, include a wiring diagram. Model SearchI did not see YVA so used XVA. If this is incorrect call them or email to ensure you get the right part. Sounds like your spark module is shot. See Item 18 in the "Gas controls" section. I would check it with a meter to ensure that it is getting power and that none of the igniters are shorted to ground. |
THIS FORUM IS DEAD!!!!!!! |
