defuk@yahoo.com
#1 Posted : Monday, March 16, 2009 10:16:17 AM(UTC)
defuk@yahoo.com
The electrician just installed our ZV950 on Friday, which has been sitting in our garage for over a year. So the warranty period has expired. The vent hood only has one of four speeds (low). If you increase the fan speed or hit press the "Boost" button, the fan motor stops. Any ideas what part(s) would cause this issue. Note that both fans are running when on low speed and the lights work as designed.
Thanks,
David E.
