booney3us
#1 Posted : Monday, March 16, 2009 6:06:24 AM(UTC)
booney3us
Guys, I just repaired a pin hole sized leak in the inlet water tubing. I cut the hose and used a new fitting to connect the inlet tubing to the valve. It seems like since I disturbed the valve for tightening the new fitting, there are 2 of the quick connect fittings leaking. Are you able to just replace the O-Rings in these fittings, or do you have to buy a whole new valve ? (This if my 1st experience with quick connect fittings)
Any help would be greatly appreciated !
Thanks, Greg
woodchuckie
#2 Posted : Monday, March 16, 2009 8:23:46 AM(UTC)
woodchuckie
Make sure you have a clean end in good shape and be sure they are pushed all the way in before you release the quick connect.
booney3us
#3 Posted : Monday, March 16, 2009 9:02:22 AM(UTC)
booney3us
Thanks I'll try that !
