Hello All ,
Have to replace the wheel on the idler arm is there an easy way to do this , I have already replaces the back drum roller and studs
Thanks for any help given
If you have already replaced the rear rollers, then you know how to get to the idler arm. The roller is held in place with a snap ring that is best removed with snap ring pliers, or work at it with what you have and it will come off.
