jtrski
#1 Posted : Monday, July 11, 2011 1:15:31 PM(UTC)
jtrski
The freezer has been warmer than normal, so i pulled the unit our to clean the fuz from the back and noticed the fan was not running. My first call recommended replacing the fan, so i did. Still not running, is there a relay that controls when the fan goes on?
#2 Posted : Monday, July 11, 2011 3:17:49 PM(UTC)
This fan, as well as most of other parts in your refrigerator, controls by the main control board which is located on the back of the refrigerator.
If the fan motor is bad, then it has to be replaced together with the main control board.
You can find more useful information in one of our previous threads: http://forum.appliancepartspros...or-test-replacement.html
You can use the same instructions for the condenser fan motor too.
- The main control board Part number: AP4436216
Condensor fan not running. power to the 3wire plug has 11.5 vdc on 2 legs. (Refrigerator & Freezer Repair)
by h60mech 10/16/2010 9:59:07 AM(UTC)
