Jill68
#1 Posted : Monday, July 11, 2011 4:40:04 AM(UTC)
Jill68
:confused:My freezer wont self defrost anymore. It just continues to run & freeze up until it eventiually cuts off the air currculation to keep it cool in the fridge part. The freezer will run and freeze till the fan stops from being iced over. I have to remove all food from it and turn it off and defrost it every 2 weeks now. The drain is not blocked, the vents are not blocked and it works fine till it freezes over. What is the problem and can I fix?
chairbornrangerx
#2 Posted : Monday, July 11, 2011 10:30:00 AM(UTC)
chairbornrangerx
I have a fridge doing the exact same thing, would be curious to see what resolves your issue.
#3 Posted : Monday, July 11, 2011 11:29:11 AM(UTC)
Replacement parts for WHIRLPOOL ER8MHMXMQ00 REFRIGERATOR | AppliancePartsPros.com
See the attachment for the tech sheet
Sounds like you may have a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle (see the tech sheet) When the fans and compressor turn off, you are in a defrost cycle.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the Adaptive Defrost Board (Item 4 in Section 3) needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 4 in Section 4) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 32 in Section 3) and measure it, should be 0 ohms when frozen. It will be clipped onto the evaporator coils. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost board is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
File Attachment(s):
ER8MH.pdf (1,832kb) downloaded 66 time(s).
