The module cover on this frig is worn out. Ice and water buttons have been pushed so many time the cover wore through. I've ordered and received the new cover, but am not sure on installation. How do I get the old one off?
I am guessing you are looking at the dispenser front cover. Remove the drip tray and there will be some screws holding the bottom in place. Take out the screws, then the entire face will slide up and off. There is a ribbon cable that connects to the control so pay attention to where and how it goes on. Then move the parts over and reinstall.
