Hi, I just got this older unit BUT it was never installed, so "like new"...no idea of the age??? Problem is a missing a part (see photo) The "piece" is round with a slot on the bottom and a screw to secure it on top connects to the drain. Can’t find a diagram showing the parts for this unit. I took it to a plumbing supply store today and showed them the disposal, they said the part should be the same as on other models that are close to the Kenmore 175.60505. Any suggestions where I can locate this part...or at least the part number? Thanks! DGB attached the following image(s):
I went to the Sears parts site 175.60505 did not come up but 175-60504 did. I think the part you want is a Flange - Item 27 in the parts breakdown - part number 5490. |
THIS FORUM IS DEAD!!!!!!! |
Thanks so much for the information.I too could not find my model number listed on the Sears site but I will try the part number you suggested and see if it fits my Garbage Disposal model. Many thanks, DGB
