tsullivan
#1 Posted : Friday, July 8, 2011 10:35:03 AM(UTC)
tsullivan
Amana washer dose not aggitate and leaks water I nned trouble shooting and repair help Please!! Tom
sidfink43
#2 Posted : Saturday, July 9, 2011 6:22:23 PM(UTC)
sidfink43
If the leak is from the center seal, and water has leaked into the transmission then the only good advice I can give is to replace the machine.
See if the motor is turning or trying to turn when it should be agitating. If it is, that will confirm problems in the transmission.
