D_warr
#1 Posted : Thursday, March 12, 2009 8:56:21 AM(UTC)
D_warr
The Frig Worked Fine Until The Red Light On Door Came On Letting Us Know To Change The Filter. So We Did And The Water In The Door Worked Immediately But No Ice. I Checked The Lines In The Back And Were Good. Checked Infared Sensor In The Freezer And Was Ok. What Else Could I Check Or Is It A Mechanical Problem?
TechnicianBrian
#2 Posted : Friday, March 13, 2009 6:00:20 AM(UTC)
TechnicianBrian
Above the ice maker is the black fill tube. See if it is frozen and not allowing water into the ice maker. This is common after a filter replacement when air gets into the water system preventing a full fill to the ice maker.
