I have a Kenmore Glass Oven/Range model #79094321302. The digital display is completely out, any button you push gets no response. When the display died this then made it where the oven doesn't operate but yet my stove top still works. Is it the control panel that needs replaced or could it be something else?:(
Although I have a Maytag Gemini double oven we have a similiar case. We have replaced the Clock part but nothing comes back on the screen. The stove top is working fine. Is there another part which controls the input of electrical power to the clock unit? Originally Posted by: indymom92  I have a Kenmore Glass Oven/Range model #79094321302. The digital display is completely out, any button you push gets no response. When the display died this then made it where the oven doesn't operate but yet my stove top still works. Is it the control panel that needs replaced or could it be something else?:(
Originally Posted by: indymom92  I have a Kenmore Gas Oven/Range model #790.77443800. The digital display is completely out, any button you push gets no response. When the display died this then made it where the oven doesn't operate but yet my stove top still works. Is it the control panel that needs replaced or could it be something else?:( Please help me.
I have the same problem, did you ever get an answer
I have exactly the same problem. I do not know exactly when the touch panel quick working but the ignitors still work so I know it is getting power. Any ideas or resolution would be great. I have only used the oven once in the 2 years I've had the stove, but I miss using the timers and clock. I've never used the oven cleaning so I know it's not from that. Help!!!
