I have a Maytag Neptune MAH9700AWW SN 1257359GL front load washing machine. I've experienced a number of problems recently, here's a brief summary: - Washer wouldn't spin fast at end of wash cycle leaving clothes wringing wet - After another couple of weeks, the situation changed. Now the washer would start filling, then get an error code and stop everything - Troubleshot per service manual, replaced water shutoff valve, water level sensor, control panel. Nothing changed the situation at all. Disconnected and reconnected wire harnesses going to motor and washer started working normally again, except for spin speed issue remains. - Called out repairman, he said it was the "speed sensor" which, of course, is part of the motor board. So I replaced the motor board and it still does exactly the same thing. - Many hundreds of dollars later, right back where I started. All wash cycles go fine until the final spin, where the speed never gets fast enough to get most of the water out of the clothes. Timer counts down fine, clothes come out clean, but soaking wet, and I have to wring them out by hand before I put them in the dryer.
Help, please! Thanks. MIike
I wish I had a quick and easy answer to this, but I don't. These machines with this type of electronics are just awful to diagnose. Here is what the service manual says to do in your case. I can only suggest you try the tests listed below. Wet Clothes
• Very small clothes loads can cause unbalanced loads. Add additional towels.
• Excessive suds may have been present, due to not using High-Efficiency detergent. Reduce amount of detergent usage.
• See Will Not Spin. • Low Spin Speed or Drain Only was selected. and here is what the "will not spin" section says" Will Not Spin
• Check to make sure the door is fully closed.
• Check for water left inside the washer. If present, see Will Not Drain.
• Perform Board Output Test or Quick Spin Test. (Before test, make sure that the tumbler is empty.) If it doesn’t tumble after the test above, check unbalanced load scenario, Main Control Board, and motor.
• Check for loose connections at Machine Control Board, Pressure Switch, Motor, Tach Harness and Motor Control. (CN8, CN9, CN3) Refer to the component testing procedure.
• Check motor winding resistance CN9 pins 1 & 3=11.6ohms ±7%, Pins 1 & 2=11.6ohms ±7%, Pins 2 & 3=11.6ohms. ±7%.
Update to my original post - my washer is FINALLY fixed!! The problem with filling up and generating an error code at the start of the wash cycle was fixed by repairing a loose connector on the motor harness, and the "won't spin above 180 RPM" problem was fixed with yet another control board change. Than goodness for ************************.com and their 100% refund policy or I'd be out over $1000 on this problem. Anyway, the washer works like brand new again. Thanks for the help! Mike
Thanks for the help, tried all that out of the service manual already. Nothing checked bad. See my update - it was actually a bad control board not letting the motor get above 180rpm during spin. Replaced control board, spins at 1200rpm+ now.
It usually is the control board on these models, glad you got it fixed and good luck going forward.
I have a Maytag Neptune model 9700 also with a similar problem and was curious if this machine is still working ? Can you tell me where the problem was on the motor wire connection ? At the connectors at the motor end or the iwre harness itself or what ? My washer will not spin ---It tries but only turns a few inches and then quits even when empty. Thanks
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I too would like to know where that loose wire was. Motor side or board side. I been chasing this problem for a while. And already replaced a few parts.
Rank: Guest
