steven hartwig
#1 Posted : Monday, March 9, 2009 9:37:48 AM(UTC)
steven hartwig
Hi Super Techs,
This is probably a no brainer but I have a gas range and the oven doesn't
regulate the oven temperature correctly. No matter what it is set at, the temperature skyrockets to 500 degrees or higher. I am assuming the thermostat is the culprit part # AP2623073. I would like to confirm this before I spend 85.74. Please respond and confirm this is correct.
Thank you in advance
Steven Hartwig
#2 Posted : Monday, March 9, 2009 6:35:22 PM(UTC)
Steven,
You are absolutely right. The new thermostat should solve the problem.
Here are the break down diagrams and Replacement parts for GE JGBS23CEH3CC | AppliancePartsPros.com
