thevinman
#1 Posted : Thursday, June 30, 2011 10:53:04 AM(UTC)
thevinman
Gas Dryer igniter goes on, then after 5 mins shuts off. The igniter gets red, calls for heat and then flames up.
After 5 mins, flame stops. After 3 more mins, the igniter gets red again but no flaming. Igniter is red for only about 15 secs only. Does same thing a minute later.
Unit runs fine but without any heat.
At first, I though it was the coil valve solenoids that need replacing, then a guy in parts store said it could be one of the 2 thermostats. Tried making connection touching both terminals on thermostat part #306910 to see if I could get flame to go on bypassing thermostat but it did not work.
Does that mean it is that thermostat or is it coil valve solenoid(s)279834 or even the 4 prong thermostat #303395
House full of guests this July 4th and need dryer. Need Help
#2 Posted : Thursday, June 30, 2011 2:02:06 PM(UTC)
The cause of the problem you described has nothing to do with any thermostats. It can be a bad gas valve coils (most likely) or a bad gas valve itself (very rare).
- The coil kit Part number: AP3094251
- The gas valve assembly Part number: AP4037259
thevinman
#3 Posted : Thursday, June 30, 2011 2:19:50 PM(UTC)
thevinman
It was the coil kit...thanks Gene
banhtimmy
#4 Posted : Saturday, December 10, 2011 12:37:56 PM(UTC)
banhtimmy
may tag mdg3000aww ,drum still run but not heat at all.what is the part need to check ???
#5 Posted : Monday, December 12, 2011 3:22:59 PM(UTC)
You may want to start the troubleshooting from checking the thermal fuse (#10 on the diagram) for continuity.
- The thermal fuse Part number: AP4043259
dlsintx
#6 Posted : Sunday, September 15, 2013 9:22:33 AM(UTC)
dlsintx
We found this thread and ordered the part; it solved our problem for $15. Last repair on this dryer (which was not the first) cost almost $300 for similar issue. THANKS SO MUCH!
