The oven will not heat up at all. The top burners all light and the broiler works just fine. When the oven is turned on, the lights on the top panel show it is on and is preheating but does not warm up. This oven is just over 10 years old and this is the very first problem I have had with it. From what I saw on your web site, it appears it may be the ignitor. Is there any other parts that could cause this?
Thank you in advance for your assistance.
Replace the ignitor. Quote:Is there any other parts that could cause this?
Yes, it could be the gas valve. Chances are it's just the ignitor. The way to tell would be to check with a clamp on amp meter. Clamp the meter on the ignitor wire and see if it draws the amount of amps that is stamped on the gas valve. If it does not replace the ignitor. If you do not have a clamp on amp meter to use then just replace the ignitor.
