Our Bosch SHU5312 UC U06 shows the signs of control module being bad, and a service tech once told us that's the case. But some of the buttons don't work either. Powerscrub, Scrubwash, Regular, and Rinse&Hold buttons just kind of "flop."
I saw in the "troubleshooting tips" manual from B/S/H/ that replacing the front cover (i.e. 264946) can repair the broken buttons, when only the buttons are broken. My question is, if I put in the control module 266746 / AP2802870, does that include the contacts for the buttons, or will I still have only one button that works?
As you can see on the picture the new control module comes with the case and the front cover. ![UserPostedImage](http://www.appliancepartspros.com/PartImage.aspx?imgid=Z3BqLjBfbXNfNjQ3NjYyL0hTQi9zb3RvaHB0cmFwLw%3d%3d) Gene.
