I have a kenmore calypso top load washer that seems to wash ok but stops when it reaches the rinse/spin cycle. it seems to get stuck in a loop where the motor starts and stops while water seems to squirt into the drum. I have taken the control console, back and bottom panels off. checked the pump and motor both spin ok and i did not see anything in the pump itself, i have also checked the continuity of the motor that also seems ok. The intake screen filters are not clogged (at one point I had to bail 20 gallons of water out of the tube so i know that water is able to enter the washer). Everything looks ok on a visual inspection of the machine and motor control boards and all the plugs and ground connections seem solid. The washer is not displaying any error codes. I suspect that one of the 2 control boards is the problem but not sure which (my guess is the machine control). HELP!!
I have this same issue. Has anyone found a solution? Hesitates and works after cools down. I've replace motor control board but issue persists. Help?!!??
