chrisc2007
#1 Posted : Wednesday, November 14, 2007 4:52:36 AM(UTC)
chrisc2007
Washer door will not close because locking mechanism seems to be frozen in the lock position. Any way to check locking mechanism to see if defective before ordering replacement part?
#2 Posted : Wednesday, November 14, 2007 6:58:27 PM(UTC)
Unlock the door manually as described on page 8 in the service manual.
In case of return problem, perform all tests recommended by the manufacturer.
Kitchenaid gas valve fix now door locked open (Oven Repair (including Ranges and Cooktops))
by michels_benny 1/17/2013 10:58:33 AM(UTC)
