My control panel was black this morning, and does not respond. Do I need a new control panel? The burners still work. I tried unplugging the range and plugging it back in.
Here are your parts, it does include a wiring diagram Model CRE8600CCEDoes the interior light work if not could be you have lost neutral. Note lights and control board require 120 volts. Turn the breaker for the stove off/on slowly a couple times. If possible measure the voltage at the plug. L1 to L2 : 240 volts L1 to Neutral and L2 to Neutral : 120 volts It is not uncommon to loose neutral without actually tripping the breaker. |
THIS FORUM IS DEAD!!!!!!! |
