jmw
#1 Posted : Sunday, March 8, 2009 7:05:10 AM(UTC)
jmw
My GE 680 Postscrubber dishwasher has stopped heating the water. The directions say to check wiring..which is fine then test the power source which I cannot figure out how to get my test leads in connection to make sure I get 120v. I know my tester works via the wall socket.
Should I just order the calrod heater replacement and hook it back up and hope it works? Directions don't provide too much more thelp than that.
#2 Posted : Sunday, March 8, 2009 7:22:15 AM(UTC)
Remove the kick plate.
Turn power off to the unit.
Remove one one of the wires from the heater
Measure the heater for resistance, should be around 15 to 25 ohms.
