BillLeonard53
#1 Posted : Sunday, June 26, 2011 12:30:05 PM(UTC)
BillLeonard53
I am replacing a drain pump on a Bosch dishwasher. The old Siemens pump had three wire connections, but the new pump only has two. I need to figure out which wires to connect and where.
The old pump had a green wire connecting on top, a gray wire on the side toward the rear, and three wires soldered together (white, black, and tan) connecting on the side toward the front.
The new Copreci pump has only two connectors, both facing toward the front of the dishwasher, with one of the connectors slightly higher than the other.
Which wires do I connect where?
