Side-by-side style refrigerator: Icemaker stopped working (no water in icemaker, but water dispenser on outside of door gets water). Found the troubleshooting guide and did the following:
* Found that the black tube that water flows from (into the icemaker) was blocked by ice. Removed blockage.
* Removed icemaker and jumpered T & H terminals. After plugging refrigerator back in to power outlet (& waiting a few seconds), the motor on the icemaker activated and at the end of the cycle, water entered the icemaker.
* Afterwards, removed jumper and reinstalled icemaker. So far, no water entering icemaker.
Is it a bad thermostat in the icemaker? And, if so, what is the part that I need or should I buy the complete icemaker assembly or the motor module?
model # is 106.53606201
looks like it was a frozen water line. Appears to be working properly now.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Water leaking out during ice making
