Can't get gas to come out of oven, cooktop works ok but not the oven. any ideas...
The first thing I would check is the oven igniter. Unplug the igniter and check if 120V is coming to the igniter when the Bake is on. If there is 120V, then replace the igniter. If there is no 120V, then replace the oven thermostat. - The part number for the igniter AP205873 - The part number for the oven thermostat AP379265 Gene.
