cgoguen
#1 Posted : Friday, March 6, 2009 4:53:22 PM(UTC)
cgoguen
My dryer started to sweak a couple of weeks ago. the noise seens to slow down the longer the dryer is use.Not sure if needs to be oiled or what, did pull back panel off and had some lint in the back.:(
TechnicianBrian
#2 Posted : Friday, March 6, 2009 6:21:43 PM(UTC)
TechnicianBrian
Is the noise coming from the front or the back? There is a bearing in the middle back that can make a chirping noise, also the idler roller can make noise coming form the lower right side in the back. A noise from the front could be failing glides or felts so it really depends on where it is coming from.
cgoguen
#3 Posted : Saturday, March 7, 2009 4:59:27 AM(UTC)
cgoguen
the sweak seens to be coming from the middle back
TechnicianBrian
#4 Posted : Saturday, March 7, 2009 6:23:04 AM(UTC)
TechnicianBrian
You most likely need a bearing kit (AP2142648) which contains all the parts that hold the rear of the basket to the chassis. It takes some work to install, but then it should sound like new again.
