Can the bottom heating element be easily replaced?
Bill, This part is not too difficult to replace yourself if you know how to handle a simple tools. Remove everything from the oven. Remove the screws holding the Bake heating element to the rear panel and pull it out as far as the wires go. Carefully remove the wires from the element. Make sure not to lose them through the hole in the rear panel. Install the new element in the reversed order. - The part number for the Bake heating element is AP3075035 Here are the break down diagrams for the Whirlpool range Model RJE365BW0Gene.
