MAREROBREAD
#1 Posted : Thursday, June 23, 2011 3:40:51 PM(UTC)
MAREROBREAD
I cannot locate the defrost timer. I looked at the diagram that came up when I put my model in and it shows it in the compressor area but we can find nothing that looks like it. The whole diagram looks different then the back of my refrigerator. Thank you for your help mairlyn
#2 Posted : Thursday, June 23, 2011 5:23:50 PM(UTC)
Replacement parts for AMANA BX22A2L REF - BOTTOM MOUNTS | AppliancePartsPros.com
The timer is Item 2 in Section 2, it looks like it is at the front of the unit behind the kick plate.
You may not be able to see it because it is mounted behind a plate.
Usually there is a hole in the plate so you can force a defrost cycle.
MAREROBREAD
#3 Posted : Friday, June 24, 2011 9:17:33 AM(UTC)
MAREROBREAD
Hey! I found it. Thanks Denman so much for your help. Marilyn
