luckeydoug1
#1 Posted : Wednesday, June 22, 2011 10:06:55 AM(UTC)
luckeydoug1
I managed to break off the screw #AP3669304 that holds the upper most spray arm assembly that is mounted to the top of the tub. There is litttle/no thread left on the screw. The rest of the threads are in the housing that the screw screws into. I am wondering the best method of removing the rest of the screw from the housing so I can replace the screw. Thanks.
#2 Posted : Thursday, June 23, 2011 3:50:31 AM(UTC)
I could not find any info on the given model number.
PSW comes up as fridges.
Unless the screw broke off in such a way that you can get a small screw driver to crab onto a ridge etc. you will probably have to replace the support assembly.
I think trying to use a broken screw/bolt puller will just screw up the support threads.
