This is a challenge now. The icemaker stopped filling. We have checked the line and every single part of the icemaker for continuity: supply valve, shutoff switch, ejector motor (although this is not the problem), holding switch, and inlet switch. We replaced the inlet valve because the supply side to the icemaker (rather than the dispenser, since it works fine) didn't register as it should, and it made sense, since all of the other parts were OK.
It still doesn't work :eek: !!! My question is: If every part of the icemaker LOOKS good, and appears to be sound electrically, why isn't it working? What could be the culprit? The only part not tested was the ice mold heater and just as soon as we get some ice, we will need that :cool: .
I don't want to give up, after so much effort. Any help out there :D ?
