funbrain43
#1 Posted : Tuesday, June 21, 2011 7:47:34 PM(UTC)
funbrain43
Fridge leaking onto floor. Appears to be running down onto frame and then to floor. is coming from evaporator (I think) Any pointers as to what to do?
Thanks,
Larry
funbrain43
#2 Posted : Tuesday, June 21, 2011 8:07:44 PM(UTC)
funbrain43
Fixed. Drain line was sitting coiled up in the drain pan. I hooked it up and all is well.
Thanks.
They should have hooked this up at the factory
