I have a Kitchenaid hand mixer, model KHM3WH, Serial # WMX47. It is approximately 10-15 years old and still works great except that the beaters keep falling out. Is there a way to fix this or is it just worn?
Thank you:rolleyes: Roger P
Originally Posted by: Roger P I have a Kitchenaid hand mixer, model KHM3WH, Serial # WMX47. It is approximately 10-15 years old and still works great except that the beaters keep falling out. Is there a way to fix this or is it just worn?
Thank you:rolleyes: Roger P I have the same problem of the beaters falling out. It seems to be frequent problem with these mixers. Is a replacement gripper part available to fix the problem and if so, how easy is this to replace?
