PATTYRYRY
#1 Posted : Tuesday, March 3, 2009 3:20:19 PM(UTC)
PATTYRYRY
I DROPPED A STONE IN THE DISHWASHER AND IT WENT THROUGH THE ROUND GRATE AT THE BOTTOM AND I CAN NOT FIGURE OUT HOW TO ACCESS IT. WHEN I TURN THE GREY KNOB (SCREW) ON TOP OF THE SPRAY ARM COUNTER CLOCKWISE IT TURNS BUT DOES NOT COME FREE. I CAN NOT GET IT OFF. CAN SOMEONE PLEASE TELL ME HOW TO GET THIS OFF SO I CAN RETRIEVE THE STONE. IN THE MEANTIME I CAN NOT USE THE DISHWASHER IN FEAR OF DAMAGING THE STONE. THANK YOU:rolleyes:
TechnicianBrian
#2 Posted : Tuesday, March 3, 2009 3:41:34 PM(UTC)
TechnicianBrian
Hold the knob with a pair of pliers and spin the lower wash arm free. Then remove the tube running up the back of the tub by taking loose the screw in the center back and up on top. Slide the tube connector on top of the sump to the right as you are looking at it and you will find the last of four screws that need to be removed to get the top of the sump off.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
